Hi, im alex.
I have a Sony Z3 phone. When i update my phone to version lolipop (5) i had great lock screen wallpaper which has z3+ and z5. I accidentally change wallapaper to green xperia static and np longer have the blue z3+ z5 lock screen wallpaper
How to get it back :(?
I also i have 1 more problem with z3 phone.
Onse on a wile my phone went to boot loop. Someetime it start showing application stopped respoding like albuk android prooccess, music, facebook, keyboard, goggle store ext...
Then my phone freeze and auto restart, then it keep say stopees working and again restart and then it freez even when booting at the purple theme while starting ot freeze and restart... After 20 restzrt it finaly turns on and says application are starting 0/193 and when its done it usually freeze for some time again and turn on and agains stsrt application and it works.
Is that a hardare releted problem or system problem
If system does factory reset or system re install remove warrenty with my phone
Hello alex
Are you talking about this lock screen walpaper ?
If yes then set the Live Xperia wallpaper and you will have this lock screen wallpaper automatically.
To do that, tap and hold anywhere on the homescreen > wallapapers > live wallpapers > Xperia > settings > chose any colour > set as wallpaper
You will have the above lock screen wallpaper set already.
I'm uploading it here as well. ( it's 5.6 MB high resolution photo)
If this is not the photo you want, then show me the one you want and I'd try to help you with it.
Regarding the abnormal crashes, you could do a software repair on your phone that would reinstall the Operating system and remove glitches, increase performance and enhance your experience.
Download Xperia Companion http://support.sonymobile.com/global-en/tools/xperia-companion/ on your PC and install it. Select "software repair and follow the on screen instructions.
hello my phone z3 went in boot loop
i keep getting every app crash!!!
it says google app crashed , android crashed , goggle store crashed , everything crash and then phone stops (freeze) and restarts and it freeze at the loading purple animation screen and keeps restarting when fianlly turns on it loads android apps forever and then it starts again apps crash and restart HELP!!!!!
hello im doing sony system repair with xperia companion
should that work
update :
hoow logn does system repair fix take?
