Proximity sensor for x10 mini pro is not working on call. Checked on Secret Menu service test. It says that proximity swith is OFF.
Please help. Thanks
repair it with Update Service, and see if that solves the issue. also do you have a protective film or protective case
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
Make sure you backup everything
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
An easier way to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
Thanks! ill try doing all your suggestions. :smileygrin:
No, id dont have any screen protector
No problem, let me know if it works out
sorry for the delayed response. i tried repairing the phone using SE update service by reinstalling the software. the update service screen showed that it was successfully repaired. but my phone doesnt turn on. when i press the on button, it just vibrates then shows black screen. no SE logo then it turns off. i tried repairing it again and the result is the same.
and now, even if i dont press the on button. it turns on automatically, then off again. on off, on off with black screen.
any other suggestions? thanks for the help
remove the battery, press and hold the power button for few seconds, put it back on, try to turn it on and also try w/o the SD and SIM cards
same results. the screen just displays black screen then it turns off.
is it possible that this is a hardware issue? before i repaired the phone. the speaker and led light also did not work already. i needed to set it on loud speaker or put an earphone before i hear anything. also, there are times that the screen becomes deformed when im opening the slide querty.
