proximity sensor issue on M4 Aqua Dual
Akash_Verma
Hi
I have just purchased an M4 Aqua dual today from the retail shop and I am having an issue with the proximity sensor.
1. As soon as I make a call, the screen shuts off. I have to press the power button to restart it.
2. Sometimes, the screen stays on, but as soon as I bring the phone near my ear, the sceen shuts off but does not start when i remove it away from my ear.
3. I did the proximity sensor diagnostic test and the phone started to vibrate even before I put it down on a flat surface... its like the proximity sensor is always on and detects an input.
4. I have performed the factory reset and even updated the phone... but the problem persists.
5. I am not using any case on my phone. Only a transparent tempered glass screen protector.
Kindly advise how I should process. Should I return the phone and ask for a replacement... it has not even been 12 hours since I purchased it and it is already showing an issue.
Best.
9 REPLIES 9
Akash_Verma
Also, If i may add, I have done a factory reset of the phone and the problem persists.
@Akash_Verma
Repair the phone with PCC and report back, does the protective film cover the proximity sensor?
PC Companion (PCC)
Bridge (for Mac)
Akash_Verma
Hi
I have updated it via PCC... but the problem still persists.
I have a transparent tempered glass cover which does cover the sensor, but i doubt it should be an issue since i have used phones before that have the cover.
Rickard
I would suspect the tempered glass cover in this case. It should have a hole in it for the proximity sensor.
@Akash_Verma
Remove the cover and check again.
gordsk
Keep your screen awake longer. Go to SETTINGS >DISPLAY > SLEEP > select a longer time period. Your phone comes with a very short default time setting.
Sandeep1pn
I had the same issue, I removed the tempered glass cover to resolve the issue
Bebobwolf
I had a tempered glass cover, and screen went black when made a whatsapp call (had to wait for call to end before i could do anything with phone). Took cover off and then worked. I noted that dirty had built up by sensor hole.(not sure if this caused problem?)
ProximitySensor
I too have same problem. I have updated with PCC & no screen cover. Both proximity sensor and ambient light sensor are not working. I purchased M4 aqua dual 1 week back
