During calls my screen flashes on and off which has lead to both me accidentally muting the mic , ending calls and accidentally putting it on loudspeeker. it only does this during calls . i cant turn the screen off with the power button as it just ends the call.
at the moment i have a screen protector on which was supplied with the phone , could this be the issue ? also if not can you give me suggestions on fixes. Thanks
(below is a picture of the screen protector and how it lines up with the proximity sensor so give a better idea , sorry about quality)
I don't see the image, but if it covers the sensor, it could be the cause of your problem.
It doesnt cover the one sensor i see *i see the front camera too
Not sure I'm addressing your issue . Just to record what I know the "power button ends the call" option can be disabled by changing the setting.
Setting -> Accessiability-> Power button ends the call (uncheckout)
I have the same issue ..but I tested proximity sensor using xperia diagnostics app from playstore, it works fine,... I couldn't find any solution till now, but tryin to use headset for important calls.
Please get in touch with service centre.. I had same issue and now given it for servicing.
same issue here
made a full reset, not helped
proximity sensor is working very bad, "hold line" button often pushed with a cheek while a conversation
Try a factory settings reset or a software repair with Sony update service.
