Problems with Xperia Play
Hi dears, i have bought a Xperia Play about 2 weeks ago, but as i bought it i found a lot of problems.
1-when i have incomming calls screen durring the ringing the screen starts to flickering but as i accept call it stops.
2-When my phone is in air plan mode or without sim card the led flash works good but as i turn off air plane the led flash starts to flickering durring video recorind or using it as flashlight.
3-when i want to work with phone with 1 finger the touchscreen(specialy buttom of touchscreen) doesnt work good but as i hold the phone in my hands or connect a usb cable(microusb connected to phone but usb in air(without connecting to charger or pc!)) the touchscreen works good.
first i think this is only my problem and wanted to change my phone but after seeing many xperia plays has all of this problems i search and found it is not only in my country's phones problem, many(or all) of xperia play users have these problems.
for example see these links:
http://forum.xda-developers.com/showthread.php?t=1279229
http://forums.techarena.in/portable-devices/1450413.htm
http://talk.sonyericsson.com/thread/16980
4-in xperia plays page(in se site) it says it could connect to livedock and use usb host  but in LiveDock page in compatible phones ther is no Xperia Play, now i want to now it is compatible with LiveDock or not?
i updated my phone using pc companion and another time with update engine to latest version (4.0.2.A.0.62), even i tasted repair option , also factory reset many times (after every update) but nothing changed. this is not my phone issue to give it to garanty i found this is only Xperia Plays issue. i tasted in my xperia x10 and xperia arc s but they works perfect but xperia plays have this problems!
Now it is important to me to know all of this problems is software problem that could be fixed later or it has hardware problem.
im waiting for your answers.
Very thanks for your support.
Johan
Since you have tested with the latest firmware and also to reinstall it I suggest that you have the phone examined at a repair center. For more information contact your local support team to find a repair center in your area.
http://www.sonyericsson.com/cws/corporate/common/contact/phonelist
Xperia PLAY is not compatible (by default) with LiveDock at the moment. But we're looking at making Xperia PLAY compatible with LiveDock as well.
