Hello together.
I got some trouble with the touchscreen.
In the upper part of the screen the reaction of the touchscreen is very bad. At nearly 1 cm of the screen there is nearly no reaction. i can touch there as long as i want and there will happen nothing sometimes.
Is it normal or is it a problem only at my phone?
That is not normal and as such I would advise first running an update/repair to rule out software and if this does not work you may need to return if assessment by an authorised repair agent:
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
