I've noticed that at high brightness levels when the background is dark(and not only with dark backgrounds) at the top right of the screen glows yellowish. The rest of the screen is almost black. (as I think it should be). The yellowish glow spreads from the top right (slightly from the top center) to middle right,forming a yellow triangle. It's horrible!
For example, I notice it a lot when the camera is turned on
Does someone else same happens?
Now I can not send you any pictures because I'm at work. I will try take some pictures at home today
Regards,
Xabi
I see, I have come to the same conclusion, I also suggest getting the handset to a service centre for repairs. Use the link below to find the contact details of Sony Xperia Support for your country.
I am also have the same issue in bottom.
