I'm using an Xperia Pro running the latest 2.3.4 release (4.0.2.A.0.58) and have two problems with the user dictionary for text-input (I use both the hardware and touch keyboards and have these problems when using either).
ISSUE 1 - POSSIBLE BUG:
Firstly, I notice that if I manually add words to the user dictionary (through the settings menu -> Language & keyboard -> User dictionary -> add), then these words do not appear in the as word suggestions when I am typing. I have my setting set to the default of "substitute letters only" for the slide-out (which I assume should also offer dictionary suggestions) and "automatically correct words" for the on-screen keyboard. (I also have quick fixes off, learn words on, gesture input on, space between gestures on)
ISSUE 2 - FEATURE REQUEST:
Secondly, the automatic word suggestion feature often repeatedly suggests old spelling mistakes to me which is quite annoying. I would like a feature where I can also view, edit and delete words which have been automatically added to the automatic dictionary (separately to words which I have added manually).
backup everything
settings -> privacy -> make sure both back up my data and automatic restore are both selected, and you can use this other options to make sure you don't lose anything
Make sure you backup everything using the Backup & Restore app
if you need the app you can use this link instead to download the apk
http://www.megaupload.com/?d=I5CJUPJV
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
once you are done backing up go to
settings -> privacy -> factory reset
once that's done, go to the messaging app -> once you see the keyboard -> tap on the wrench icon -> text input settings -> UNCHECK learn words, quick fixes should be selected, tap on word suggestion -> selec Suggest words, don't correct automatically
and re add words to the dictionary
settings -> language & keyboard -> user dictionary -> menu -> add
uliwooly, thanks but wiping my phone is not something that I am not going to do lightheartedly. Before you jump the gun, could you and any other users please tell me if you are having the same issues before I'd even consider it?
I have had this issue as long as I've had my phone (with original 2.3.4 release), and strongly suspect it to be a software bug which SE needs to fix in an update.
uliwooly, is this a known issue and can you confirm that others have fixed it this way?
it's a software issue, way back with the first Xperias. the only way to delete all those words/typos is to do a factory reset, if you follow my suggestions above you won't lose anything.
if you follow this steps once you do a factory reset
Go to the messaging app -> once you see the keyboard -> tap on the wrench icon -> text input settings -> UNCHECK learn words, quick fixes should be selected, tap on word suggestion -> selec Suggest words, don't correct automatically
you won't have that issue, since the phone won't be learning words (typos) only the words that you add to the dictionary
yes, but I LIKE the fact that it automatically learns words. In the second part of my post, I am essentially asking SE for a new feature in an update to allow users to edit these auto-added words.
What exactly does setting "quick fixes" do and what is your reasoning for setting this? (I don't want two spaces to be converted to a period and space). I also LIKE the setting where it converts u to ü etc. in certain words. What is the reason why are you telling me to set things like this? Is it a known workaround to a bug or what?
there is not work around it, if you leave the settings as you have them, to learn words, it will learn EVERYTHING you type, even typos, so the more typos you make, the more typos you'll see as suggestions, there are other keyboards on the market that you can use that might or might not work for you. remember it's a smartphone there are myriad apps that can customize your phone as you want. please check the market, it's easier to find apps using your computer, go to
market.android.com
