Problems with syncing calendar
spudval
Hi
i'm trying to sync the phone calendar (standard one supplied) with outlook on my laptop.
i'm using the pc companion, which tx the contact etc but not the calendar.
i've ticked everything that looks relevant and been in the phone setting areas and the calendar settings but nothing seems to work.
can anyone advise what i need to do.
thanks
s
manjuboyz
Hi spudval
  try this
>settings -> apps -> all -> calendar -> clear cache/Data( if you are selecting Data then all calendar datas will be erased so it is good if you have back up) then try to disable the app on the same page, restart the phone and try it again, hopefully it might work
let us know
Manjuboyz :smileyhappy:
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks :smileyhappy:
