I bought the device above a month ago and suddenly the machine display does not turn on the device I Charger connector red light comes on
However, there is no
The device is loaded include panel
New Device Works month
Are you able to turn on the phone? if you are, try calling it to see if the call goes through, if it does then you might need a new LCD, if it doesn't the issue might be greater, contact your Local support to get your device inspected.
