problems with software upgrade, x10
whilst trying to do a software upgrade via pc companion i get to the part where it asks me to remove the data transfer cable, turn phone off, wait 5 seconds , plug cable back into laptop and then hold down the back key whilst plugging the cable back into the phone...i do this and nothing happens apart from the phone starts charging from the laptop.
I have tried this several times and although the instructions dont say anything about turning the phone back on i have tried it both ways, leaving the phone turned off as i think is the right way but also turning the phone back on as  i was at a standstill.
Any help is greatly appreciated.
6 REPLIES 6
Once you update to 2.3.3 the Backup & Restore app will be gone, BUT you can reinstall it this is how, and also make sure you backup EVERYTHING before the update
make sure you backup everything beforehand
this is how
Use one of these links to download the Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
if the Update it's not available on your country, this is how to manually update your phone
http://talk.sonyericsson.com/message/90716#90716
thanks for all those tips....but still it wont do anything when i hold down the back key...tried my laptop in safe mode too....grrrrrrrrr
slimshaddy
Hero
might be dumb..but first connect the cable to your phone...then press the back button and then plug the cable in your laptop..i do the same Smiling_Face_with_open_mouth_&_closed_Eyes
also your battery should be more than 50% charged,,
Jake-SonyXperia
If none of the above works, Then I could suggest trying another PC as it could be related to the Laptop you are currently using.
