Problems with Smart Wireless Headset - MW1, and a wishlist!
Lansen
Here is a list of features that I want to implement in WM1 as soon as possibly and some problems...
The Music player...
* Folder list
The user interface of the player should have the possibility to not only base on artists or albums, it should also use the folder structure. Each folder which contains audio files should appear in the list separately.
* Quickly switch between folders
If you select a folder in the folder list, it should start exactly at the last played position. This allows you to quickly switch between folders.
This is particularly suitable for people who often want to switch between music and audio books/podcasts.
* Shuffle files within the current folder.
* Shuffle files of all folders
A firmware update that help when music stops all the time when using the phone. Music is interrupted when accessing the phones menu system...
The Radio...
When scanning the radio frequencies it should remember the stations so you could jump between them instead of always have to do a new scan. Or have the possibility to store the stations.
New headphones is needed!
Slightest touch of wires propagating in to the headphones, and it sounds loud. If you sit completely still they are quite good. Other material in the cables and these headphones are acceptable. I have never experienced this problem with headphones before. I am not alone to have this problem! This is the single thing that is it is worst with an otherwise very promising product.
There is no attachment for a neck strap. It would also be a great feature to include in the basic package.
Richard B
6 REPLIES 6
Johan
I will forward your feedback to concerned team.
Lansen
Thanks... I could buy one more if you include these features and fix the problems... Slightly_smiling_Face
Lansen
I have found out another problem that is very annoying. When I am using the clips and put it somewhere on my clothes I always seems to end my call in progress...
This is really a big problem... The button to end the call is just opposite the clips and when you use your thumb on one side and the finger on the other you press the button and end the call...
This button should be on the other side of the MW1. Today my friend that just bought this MW1 have ended at least 10 calls accidentally and he is angry... Slightly_smiling_Face
e_luinstra
+1 for a folder list that shows the hierarchical structure of all folders as they are stored on the SD card and the music files stored in these folders. In this way you can easily navigate through your music.
flipside
Radio
- preset storage for the radio
Music Playback
- Folder view
- Time left / time played shown for music playback on the headset and if possible on the phone
- Podcast folder in list with possible playback speed option
- Audiobook folder with possible playback speed option , Audible compatibility would be good
- Intelligent fast forward - by that i mean FF that speeds up the longer you hold the button down
interface
is it possible to list more than one track at a time
alinefx
Sony has updated the hardware on the headseat and the clip now has a slight ridge on the edge to prevent that from happening. See here:
