Support team,
I have been facing problems with my receiver, that is when I take phone calls, I am not able to hear the person who is speaking. I have checked the 'in call volume' and the in call volume is full. Is there any other setting that I could check? Or is this a hardware problem? How should I have this addressed? Please advice. Thanks!
You can test the ear speaker via the service menu.
Enter *#*#7378423#*#* in the dialer. Service test > Earphone.
If it doesn't work check if a software repair via PC Companion could fix it.
If not it needs to be fixed at an repair center. In that case contact your local support team.
