problems with my Sony Xperia C4 dual
mshawali
after i upgrade my Sony Xperia C4 dual to andriod 6 via my computer ad after i start my phone i keep get this message "unfortunately the process com.android.phone has stopped" also i restarted my phone in safe mode i get the same message "unfortunately the process com.android.phone has stopped" anyone can help?
3 REPLIES 3
CameronT
Hi @mshawali,
Welcome to the community.
I am sorry that you're having issues with your C4 Dual Slightly_frowning_Face
I recommend you run a software repair using Xperia Companion as this is likely to resolve this for you.
mshawali
thanks for reponding is there any way else either repair? and when i make repair all apps and data will be lost right? is there any way to backup my apps and data? i try to use backup from phone to SD but it didnt work
CameronT
@mshawali,
There's not really another way to do this as it is happening in safe mode too, it would indicate the problem is in the firmware. So, I believe reinstalling the firmware should do the trick.
It will delete your data yes, so to back up your phone, see this thread: http://talk.sonymobile.com/t5/FAQ/How-to-backup-and-restore-your-files-using-Xperia-Companion/td-p/1...
