problems with my calls
Every couple of calls my screen blacks out and I cant end call or see anything on the screen. I try pressing all buttons nothing works so I have to take battery out and reset. Is there anything u can do to solve this???
4 REPLIES 4
you should repair your phone with Update Service or PC Companion
also go to settings -> about phone -> android version
do you have 2.3.4?
are you using any protecting case?
make sure you backup everything before
Use one of these links to download the Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
this is zee 27 but the computer lost me so ive re registered i have anrdoid 2.3.4 no case and is now doing it every call ive updated for over 3 hours tried to reoaur but it keeps getting to preparing phone then pc campanion freezez and i have to start again. im getting frustrated with this what else can i do...
As you have problems with PC Companion I would try Sony Ericsson Update Service (SEUS) down load from the following link, ignore the Aino - you get to choose your phone when running the programme.  I have always found SEUS to work where PC Companion fails.
Aino™ - Update Service - Downloads - Mobile phones - Support - Sony Ericsson
