Hello there.
I have a problem.
I'm using my laptop as an internet hotspot using program mHotspot. I'm connecting to this network using another laptop and my Xperia Z2. I was using it for like 2-3 weeks already and everything were working fine but suddenly it stopped working correctly, I mean my phone doesn't have internet anymore. I doubt it'd be a problem with that program because my second laptop has internet access all the time with no problems.
I was searching on the internet for many solutions but nothing I found worked.
The problem looks like that:
Everytime I'm trying to load some site (google, youtube, anything) I'm getting an error: This web page is not available. I can ony Reload or Show details. I click on "Show details" and it says that the server can't be found because the DNS look-up failed. There are some solutions to this problem but none works, I tried them already. On the bottom of the page it shows Error code: DNS_PROBE_FINISHED_BAD_CONFIG. Okay I get it, its something with DNS configuration but I can't figure out whats wrong. I tried changing DNS address in wi-fi settings but it didn't work.
Looks like its a problem only with my internet browsers (I tried using both Chrome and Dolphin browser) since other apps which uses internet connections (like Skype, Facebook messenger) works fine (except for that avatars are not loading at all).
Could someone please tell me how to fix it? I don't know what to do anymore.
also I'd like to add that I wasn't changing any settings on the phone before the error appeared. I was browsing the internet at the evening and at the morning it wasn't working anymore.
I'm afraid i'm not familiar with mHotspot but it sounds like it's not providing correct DNS settings over DHCP and that you need to enter them manually in the phone. You can do this under Settings -> WiFi -> [tap and hold the network] -> Modify network -> Show advanced options -> IP settings -> Static. But for information on what settings you should use you need to check with the support for mHotspot. I suspect you should either use the DNS from your ISP or enter the IP of the virtual interface created my mHotspot.
