Hi there !
I think i need to talk to the support but first, i would like to see how far can help the community
Since i have my brand new C5 ultra dual (like 3 weeks ago), I have more and more problems with it !
First, it had a charging problem, the charging cable wasn't detected : solved by buying a new one.
A few days later, the phone came with a new problem, and the screen started to block during videos or musics and the sound blocks too ! It makes it more and more often...
And it's about 5 days now, that the phone disconnect itself from the Wi-Fi and when i go on the Wi-Fi menu, it reconnects itself automatically.
AND today, i woke up with 100% battery, after restarting my phone a few minutes later, i had only 15% battery left !!
Don't now what's happening but I am pretty sure it's a manufacturing default... Isn't it ?
Did you had these problems ? And do you have some suggestions to solve them ?
Sorry if my english isn't perfect and if you don't understand everything !
Thanks for reading and for help !
Hola Hola Rapha!
Correct me if I am wrong.. you bought the phone, you connected to wifi and immediately got one or two system software updates, right? And then upgraded from Lollipop 5.0 to Lollipop 5.1 - Correct?
Well, the same behavior that you are describing happened to me, fixed with a Repair.
Download the Sony Companion Software:
From here in English: http://support.sonymobile.com/us/tools/pc-companion/
From here in Spanish: http://support.sonymobile.com/mx/tools/pc-companion/
Install it, connect it and select to repair your device. Before doing that, do a backup. After the repair I bet your device will be smooth and without too many problems.
I am just new to Sony mobiles... got my Xperia C5 Ultra Dual EE5533 about 2 weeks ago.
It updated to 5.1.
The thing I do not understand, the wifi is always uploading/downloading all the time takining most of the bandwidth from my ADSL.
I thought at the begiining that my cloud services are syncing to my mobile, but for 2 weeks?!!!
How can I solve this issue?
Thanks
@limopc Have you checked if auto update for your google play app is enabled? That will take some of your available data plan.
Thanx alexdon
My google play is set to autoupdate over wifi only.
weather there are updates or not I see wifi working all the time... and I mean really ALL the time.
@limopc In your first post, you said you only use wifi. Are you talking about mobile data?
My post is mainly about wifi.
It shows all the time sending and receiving, and slowing down my
ADSL internet spead.
Go into advanced wifi settings (tap the 3 dots in wifi settings) and check if scanning always available is enabled and keep wifi on during sleep is set to always.
alexdon
(it's still me limopc but had a prob with my login)
Thanks, I found the settings you mentioned on my mobile as you mentioned already.
By the way, I have logeed out of google drive, dropbox and one drive... to be sure it is not syncing anything
But still the same
If you don't want to sync anymore, go to settings-accounts, tap on 3 dots and untick auto sync data.
