When I am receiving calls, I slide the green answer button to the right and it just 'hangs' there without answering the call. The phone keeps vibrating untill the caller hangs up and this can take up to 30 second. When the caller tries again it sometimes works but mostly people are unable to call me and also i am unable to call them. When I want to make a call, the phone does not do anything, it doesn't make a call, it doesn't show it is trying to make a call and sometimes after about 10 seconds it even suddenly shows up the call timer and I hear the dialed person on the other side talking to me as if we were calling already for some time. It gets frozen a lot, or when I call someone, even after the person takes the call, it still vibrates and acts as if it was still trying to get connection, even if i hear the person already.
I found many discussions about this problem on the internet where a lot of people are experiencing exactly the same problem as i do but i was unable to find a solution for this. please help me or do something about it because the phone like this is unusable!! Thank you
Xperia P is known to have some issues with lag,but have you tried a software repair until now?
Hello , ı have too this problem
Is there any different solution ?
Max,I do not think there is much you can do.Did you try a sony service?
root your device and jus flash a custom rom .. problem solved . sony is not going to help u anymore ..
