Hello everyone,
The day after making update of ICS I start to have several problems with my Active.
First of all, the battery is just loosing energy like insane. I charge fone in morning, and in the evening battery is on 6-7%. And I use it the same way like before, only talking, texting, RunKeeper. Before update 2 days of working, after only 12 hours.
Next one, Active start to switching off to safe mode, where I can call only on emergency numbers. So I have to use pin code to start to work it again. 2-3 times a day, and every time when battery hits 15%. Its like crazy "save energy" mode. Before update, no problems. Now I start to hate this fone.
Any suggestions?
try to repair the phone using SUS.
and also try not to cover the upper part of the phone (seen the 3 gold thingy on the upperback inside? )
try to check your network settings.
I had this problem too search for my older posts...the solution is offcourse downgrading.
I have SUS, I have use it to update last time.
When I connect phone now, only information that I have, is that I have latest software, and if I have any problems I can make update again. I dont think is a good solution
Edit. 16.08.2012 Today I have made update again, via Update Service. Everything starts to work perfect, battery and network:-)
