Problems after screen repair
Yothor
Hello !
I have my Z3 screen repaired by a specialised shop.
Since then, the screen is again broken (i think they did bad work). And the phone warms more than usualy.
Someone have an explanation?
Tags (1)
8 REPLIES 8
Hampus
If the screen is broken, it's unfortunately not much we can do at the forum. I suggest that you visit nearest to have the phone examiend/repaired by a technician. You can contact your Local support for information about nearest service center and/or how to proceed with this in the best possible way.
The phone will heat while it's in use or when it's connected to the charger, this is not abnormal. If the phone gets to hot, the phone will display a message about this and power off to prevent overheating.
Yothor
Why the phone is more warm since they repare it ?
Yothor
OK... Do i buy a phone or heating equipment ?
Hampus
All the phones can get warm. For example, if you use your device to talk, transmit data, or play games or music for an extended time, the device may get warmer. This is normal because in these conditions the device uses more power than usual and therefore generates more heat.
Yothor
I know this fact... But what can we do if it's too hot ? No photo... No Web... No games... Nothing. Nothing since this repair.
@Yothor
There are myriad factors that affect your phone's performace, if you have WiFi on it will drain the battery faster and heat up your phone a lot faster that if you are on data, with that said, if you have poor network coverage it will heat up your phone and drain your battery rather quickly, also, background apps and services will add to this.
Yothor
I don't speack about performances! But about heat. I know that Z3 have heat problems, but it's worse after this screen repair
@Yothor
I don't know if you have done it already but I would repair the phone with PCC
PC Companion (PCC)
Bridge (for Mac)
