Problems After factory reset.
Curnow1
I had to make a hard reset because the phone was lagging a bit so i decided to remove all apps ect.
My first problem is that the Lockscreen's wallpaper isn't the Sony Xperia Z3+ one. It changed back to the normal Xperia changing color wallpaper. I tried doing some tricks with the themes but nothing worked
Next problem is that when you have the screen locked and turned off , when i said "Ok Google" It always turned on the screen at started searching things even when i had pin code. I went to the Language and Input , Google voice typing , then "Ok Google" Detection , finally activated all settings "From the Google app" "From any screen" and "Trusted Voice" However nothing is working , only when the device is charging it lets me say Ok google and it will turn on the screen but before the factory reset it showed up without charging.
This isn't a problem but it's very annoying , when i turn on the screen to unlock the the little padlock decal at the bottom is all the time in a circle so when the screen turns on when a notification comes up the circle keeps blinking and at night its bery light , lighter than the rest of the screen and its annoying
does anyone know can i fix these issues??? I really like the wallpaper and the ok google when the screen is off.
Rickard
Are you sure you had  "Ok Google" working before when screen off and no charger connected before the master reset? This doesn't work for me and i remember reading an article from Google saying that is only supported on a few devices. I think it was Nexus devices and 1 or 2 Samsung phones but i can't seem to find the article again.
Regarding the wallpaper on the lockscreen i'm afraid i'm not sure which wallpaper you are referring to. The default in my Z3+ is the one in the theme Xperia. What did it look like?
The ring around the lock comes from Smart lock so if you disable all smart locks you will not see the ring. But for me it's much less bright than the clock.
