Problem Xperia U with ADB Eclipse
ferox
Hi to all,
I have installed Pc Companion on my laptop whit Windows 7 64bit.
My computer identify the device (Xperia U) and also Pc Companion identify it....
I enabled the "debug mode" in "settings", of my phone.
Now when I connect my phone to the pc, Eclipse doesn't recognize the phone as a device, so I can't use my phone to debug an app.
I tried installing this drivers:
http://developer.sonymobile.com/downloads/drivers/
But when I try to update my actual drivers, windows say me that there aren't any drivers in that folder.
Are this driver for Windows 7 64bit?
Thanks, and sorry for my english...
3 REPLIES 3
Johan
I will pass this on to our developers to have them check. I will get back to you.
Johan
I got some response. Have you tried to uninstall your current driver and PCC and then install PCC again and connect your phone?
Because PCC contains the drivers that you need.
laplada27
I have the same problem, and tried many things. ADB devices won't see my Xperia T.
- Fresh boot Intel 64bit Win7 English
- PC Companion installed (and updated)
- Xperia T plugged in USB, ask to install PC Companion (press install, no sure why it always asks)
- Xperia debugging turned on, ask again to install PC Companion (press install again)
- run adb devices, nothing
- tried to kill adb.exe and start it again
- tried to force updating the driver with the one provided w/ PC Companion (windows says the best driver is already installed)
- tried to force updating the driver using the android generic usb driver (same thing)
- Windows Device Manager only sees a Portable Device Xperia T (no Other Device, no ADB what so ever).
- my Xperia T indicates me Internal Storage & SD card, and USB debugging connected
- Windows detected an Xperia T and an LT30a (I saw the pop ups).
I am out of ideas here, and bought that phone, because I could not get my Xperia Mini Pro to debug either. So far not a good experience. Also I contact support via email several times, only got one answer saying that I need to unlock my phone to debug with it??? not sure about that.
Please help! Please....
Thanks, Daniel.
