Problem with Xperia Z1 Camera
andrei_ghi
Hello,
I recently bought a Sony Xperia Z1 and I have a thing I wanted to know, not sure if it's a problem.
When I try to take shots at night, before I press the shutter button the whole image looks very grainy. When I actually take the shot it comes out ok.
What it bothers me is that it's a big difference in quality between what appears on the screen before I take the shot and the actual picture which is ok. Is that normal?
Thank you very munch in advance. Hope I made myself clear.
4 REPLIES 4
Phy
Legend
Legend
That's normal, are you using manual mode or superior auto?
andrei_ghi
I am using superiou auto. Thanks for your response!
Phy
Legend
Legend
Uliwooly posted about that, it's called pixel binning
/t5/Xperia-Z1-Z1s/Does-the-Z1-use-pixel-binning-when-shooting-at-8MP-shots/td-p/389569
http://www.engadget.com/2013/09/24/sony-xperia-z1-review/
Importantly, the Z1 shares a key technology with the Lumia 1020 in the form of downsampling. Whereas the Lumia creates downsampled 5-megapixel still images from its 41MP sensor, the Z1 uses similar mathematical techniques to produce 8MP stills from a 20MP image. And although the sampling ratio is smaller, the impact of Sony's "pixel-binning" is immediately visible and beneficial. You lose resolution on your final image, of course, but you also lose lots of nasty image noise.
andrei_ghi
Thank you very much for your reply! :smileysmileythumbsup:
