Hi
Recently I am facing a strange problem with the camera button on the Xperia Pro. When I click the button it only locks the focus but does not take a photo (no matter how hard I press it). This happens in most cases and on rare occasion it does click the photo as well. Having said that the touch focus works just fine - it not only focuses properly but also takes a photo in a jiffy. No idea why the physical button is struggling.
Is any body facing a similar problem - what could be the possible solution?
Do let me know
thanks,
Pushkar
can you take the picture if you touch the screen?
if it's a software issue you can fix it with Update Service to repair your phone
Update Service (SUS)
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
SMS/MMS/Call Logs
Install "backup SMS+" to back up your SMS, MMS and Call Logs to your Gmail
or just SMS use
"backup & restore SMS"
or just MMS use "Save MMS"
Call Logs (Just call logs)
Contacts
open your phonebook
on your computer
Backup & Restore app (will backup your SMS, MMS, Call Logs, Settings, Apps, Contacts)
Use one of these links to download the
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
download the app, transfer it to your SD card
Download Apk Manager
https://market.android.com/details?id=com.magmamobile.app.apkinstaller&hl=en
open "Apk Manager" and voila select the apps that you wan't to install
Apps
Don't worry so much about backing up your apps
on your computer go to: market.android.com -> log in -> click on My Library -> and send all your apps to your phone
Make Sure to mark the Correct Answers & Helpful Answers
How to sideload apps
1st Method
How to install it
You need to
download IO File Manager
download the app on your computer, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
2nd method
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
3rd Method
BOX and upload the apks from any computer
install the App on your phone -> open BOX -> tap on the app -> install it
4th Method by far the easiest
an even Easier alternative
Yes, I can take the photos with touch. I recently reinstalled the software and the problem continues.
are you using a protective case?
No - it was all working fine initally - but not after I re-installed my software (if I remember correctly).
run SUS again and see if the problem persists if it does then you should contact Sony Service Center as it might be a hardware issue
http://www.sonymobile.com/gb/support/contact-us/
