problem with Xperia inside face book
anasdel
Heiiii....I bought Xperia P n upgraded to ICS n nw Xperia inside facebook is nt working.content pictures is nt updated bt calendar workes..bt dont ssyic to contact.. Also when trying to connect a app like IMDB o subway sufer through Facebook a whit.when I tick tht option a white page come n a loading box pops n goes n come back again n again... What can I do to solve this already tried reinstall my software n repaired the phone..still nt Woking....
2 REPLIES 2
anasdel
Plxx can someboy help me.. Slightly_frowning_Face Slightly_frowning_Face
Miltos95
  1. Head to https://www.facebook.com/settings?tab=applications&section=opt_out&view
  2. Find the app that's called "Xperia™ Smartphone from Sony" and remove it.
  3. Go to your Phone and re-enable facebook inside xperia, make sure the "Contacts" is checkmarked under the "Select applications".
  4. Open the facebook app, press the menu key and pick Settings.
  5. Scroll to the bottom and pick "Sync Contacts".
  6. Choose if you want to Sync all your Facebook contacts or just the existing contacts.
Hope this does fix the problem.
(Make sure the Sync is On under Accounts & sync on both services, plus the whole thing on the top!)
P.S.: Facebook inside xperia might not wanna sync and display an error on the notification bar, just restart your Phone. If that doesn't work turn off sync under Accounts & sync and re-enable it.
