Hi @LustigesPeterle,
Welcome to the community.
I am sorry you're experiencing heating issues with your camera. This is normal though. The higher quality the video, the more processing power it will take, and the more it will heat up your CPU. When your phone gets hot, it will give you a warning and stop any apps that are causing the heat in order to protect it from damage.
If you wish to record longer videos, you could try lowering the resolution. I apologise if this has caused you any inconvenience.
