Problem with Viber on Xperia V nya version Jelly Bean 4.3
Buli
I have problems with viber for new update 4.3 for long sen.I have tried to fix it by resetting the phone, repair, update everything, but the same error occurs, after a few seconds call on viber, I can not hear anything, the votes upphör.Jag've tested with old versions 4.2 and 4.1, it was quite OK, but 4.3 has Never operate fixed that error even after new update 9.2.A.2.5, no improvement at all, so I was compelled to downgrade my phone from 4.3 to 4.2 ., if you have any better suggestions, please write.
5 REPLIES 5
halfamobilexper
the viber app has sopet voriknig on more than just your phone so it is not entirely spesial. try reasetting the phone and not uptate it check if it still works. the chek the viber teck suport, if it exsist that is. i have used vber mysel but stopped because of bugs. goo luck
profile.country.sv_SE.title
ViberMedia
This is an issue that we are aware of. We are currently looking into it and hope to have a solution for you in the future.
annoy
I had solution and for me it is worked. Install latest viber version and restart the phone. Turn off gps, and off the location accessand turn off the all gogle location setting and change the ringtone. For me it is absolutely worked.
emporium
They did not solve this problem yet, issue started with viber version 5, I tried all updates and have same problem like in first post. I use older version of viber now, it is Viber 4.3.3.67, works fine, but there is no video call in those old versions.
annoy
Please update to vibersion 5.3.0. This version solved all issues. Before i had many issue. after voice calling, other side hear nothing and my mic does not work. But after updating viber version 5.3.0, all are fine, video calling,voice calline and everything is fine.
Update and enjoy with your familys friends with new viber version.
Be usefull my help.
Tags (1)
