I have a proper internet connection and have no problem connecting to gmail, facebook and other apps etc but when I try to update existing apps it starts downloading but it doesn't stop......after waiting a while the percentage doesn't come up and I have to force it to stop...... i then have to go into setting to clear cache otherwise it will try to start downloading again....
I have left it over an hour to download an update of approx 11MB.
I never had this problem before
Is ther something in settings i need to check?
have searched all troubleshooting and forums...
Do you have enough internal storage?
yes, 10gb available
Try this: Main Menu > Settings > Apps > All > Playstore > Clear Cache > Uninstall Updates > try to update the apps again.
Thanks, will try that the next time.
Ended up restoring factory settings which was the last thing i wanted to do but it worked so all good again.
