Hello guys,
I recently upgraded to ICS and it's very smooth except for the occassional lag or two which I honestly don't mind. I mean it's not one of those things that make you wrench your hair in frustration. Multitasking is decent as well. But the upgrade is always appreciated.
I plugged in my USB cable-to charger and put my phone on charge through a socket. To my disappointment, the touch response started misbehaving horribly. The home screen when long pressed doesn't give me the list of recently used apps, but instead kept sending me back to the home screen again and again and again. Also typing is a pain in the neck..everything I type ends up being typed twice or thrice. Althought this doesn't happen when I use my Dad's Samsung charger. The phone works fine when it's not charging though. Any solutions or suggestions? Also the battery life isn't really impressive..
I guess there must be the cable or charger acting up. Probably some kind of ground problem because capacitive screen are really sensitive to this. I suggest that you contact your local support team to check if your can have your charger replaced.
