Problem with t715
Problem with t715
Hi there is a problem with my t715 , when I call or receive a call ,I cannot hear anything .on the other hand if I turn the speaker on then it works fine and I can hear everything , any suggestions what to do ?
Dr_Chris
http://www.sonyericsson.com/cws/support/mobilephones/downloads/t715?cc=gb&lc=en If it isn't the volume settings or the phone set to silent mode, I would first of all suggest you try a master reset: Main menu--Settings--General--Master reset--Here, try a soft reset (Reset settings), followed by a hard reset (Reset All). Otherwise, try updating/re-installing the software with SEUS and/or a phone repair with PC companion.Failing all of this, it's probably a hardware issue which needs to be repaired at a service centre. Don't forget to back up your phone data on PC/PC Companion/memory card before the update/reset/repair. Hope this helps.
