Problem with Playlists Syncing
rkuk2k
Hi there,
I own a mac on 10.6.8 - I am having serious trouble syncing my playlists on my Xperia T external 32gb SD card. I have tried various methods:
sony bridge for mac
win amp syncing to both the phone and & the SD card on its own
transferring direct to the sd card via an adapter.
This has resulted in various things -
The Sony Bridge app has had various results, sometimes losing all of the music completely - even though when I look on ASTRO I can see that the music is there. Some playlists appearing while others didnt. Also is the software intelligent enough to realise that a track can be in many playlists?
The first time I used winamp to sync with the SD card on its own, instead of showing 40 playlists the walkman app detected 80, some of which it didnt add any songs too at all. It looked like it had duplicated the majority of them.
I have restarted my phone, unmounted the SD card, done all sorts to try and get it to work. Does anyone have any suggestions as I am getting very annoyed at this. With my old iphone I would just go into itunes press sync and everything worked perfectly - all this has done is add anger and confusion.
At the moment I am in the situtation where I have just used winamp. I put the micro sd card in the adapter and sync'd my playlists. This seemed to trasfer ok, I can see he m3u files. However, no apps are able to find them. When I tap the m3u file in astro and select play in walkman it just hangs.
I have just connected to sony bridge for mac and it is telling me that all playlists have syncd ok but I cant see them in walkman or winamp.
Hope someone can help.
Thanks
2 REPLIES 2
Johan
I think that we have to check if this problem is related to the phone app's or the sync software.
Do you run into the same problem if you transfer local music files with playlists from your computer to your SD card?
rkuk2k
Hi there,
Thank you for your reply. I managed to get it to work last week after many many tries. I had to turn off USB mode and for some reason after re-opening the software for about the 10th time a playlist sync'd with no errors or without it hanging. With this in mind I then sync'd one playlist at a time, which took about 6 hours (about 15gb of music I think).
If it helps, I have a log from one of the errors which I will attach below.
I have just connected my phone to my laptop for the first time since last week after I purchased 3 new songs. Unfortunately it has hung again two times in a row. I think its a software problem, but I'm not sure?!
Date/Time:       2012-12-02 12:05:27.448 +0000
OS Version:      Mac OS X 10.6.8 (10K549)
Report Version:  6
Interval Since Last Report:          109427 sec
Crashes Since Last Report:           65
Per-App Interval Since Last Report:  29586 sec
Per-App Crashes Since Last Report:   6
Anonymous UUID:                      8B9C957F-7CB6-49FD-B991-9749ED71CF85
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread:  8  Dispatch queue: com.apple.root.default-priority
Application Specific Information:
*** Terminating app due to uncaught exception 'NSRangeException', reason: '*** -[NSConcreteMutableData replaceBytesInRange:withBytes:length:]: location 4103457496exceeds data length 3087606'
*** Call stack at first throw:
            0   CoreFoundation                      0x935d96ca __raiseError + 410
            1   libobjc.A.dylib                     0x94e295a9 objc_exception_throw + 56
            2   CoreFoundation                      0x935d93f8 +[NSException raise:format:arguments:] + 136
            3   CoreFoundation                      0x935d936a +[NSException raise:format:] + 58
            4   Foundation                          0x92641e0e -[NSMutableData(NSMutableData) replaceBytesInRange:withBytes:length:] + 354
            5   DeviceConnectivity                  0x0046a5b8 -[DRMetaMP3 embedAlbumArt:intoData:] + 377
            6   DeviceConnectivity                  0x00468fbb +[DRMetadataUtils fileDataWithInsertedAlbumArt:] + 446
            7   DeviceConnectivity                  0x0043079f -[MSCDevOpSendFile doStart:] + 3092
            8   DeviceConnectivity                  0x0042fb89 -[MSCDevOpSendFile main] + 348
            9   Foundation                          0x925b4b5a -[__NSOperationInternal start] + 705
            10  Foundation                          0x926a50bb ____NSOQSchedule_block_invoke_2 + 119
            11  libSystem.B.dylib                   0x93a01a24 _dispatch_call_block_and_release + 16
            12  libSystem.B.dylib                   0x939f3cf2 _dispatch_worker_thread2 + 228
            13  libSystem.B.dylib                   0x939f3781 _pthread_wqthread + 390
            14  libSystem.B.dylib                   0x939f35c6 start_wqthread + 30
Thread 0:  Dispatch queue: com.apple.main-thread
0   libSystem.B.dylib             0x939cdafa mach_msg_trap + 10
1   libSystem.B.dylib             0x939ce267 mach_msg + 68
2   com.apple.CoreFoundation         0x935422df __CFRunLoopRun + 2079
3   com.apple.CoreFoundation         0x935413c4 CFRunLoopRunSpecific + 452
4   com.apple.CoreFoundation         0x935411f1 CFRunLoopRunInMode + 97
5   com.apple.HIToolbox                   0x902cee04 RunCurrentEventLoopInMode + 392
6   com.apple.HIToolbox                   0x902cebb9 ReceiveNextEventCommon + 354
7   com.apple.HIToolbox                   0x902cea3e BlockUntilNextEventMatchingListInMode + 81
8   com.apple.AppKit                         0x90ab5595 _DPSNextEvent + 847
9   com.apple.AppKit                         0x90ab4dd6 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
10  com.apple.AppKit                       0x90a771f3 -[NSApplication run] + 821
11  com.apple.AppKit                       0x90a6f289 NSApplicationMain + 574
12  ...ony-Ericsson-Bridge-for-Mac  0x00002b2d start + 53
Thread 1:  Dispatch queue: com.apple.libdispatch-manager
0   libSystem.B.dylib             0x939f4382 kevent + 10
1   libSystem.B.dylib             0x939f4a9c _dispatch_mgr_invoke + 215
2   libSystem.B.dylib             0x939f3f59 _dispatch_queue_invoke + 163
3   libSystem.B.dylib             0x939f3cfe _dispatch_worker_thread2 + 240
4   libSystem.B.dylib              0x939f3781 _pthread_wqthread + 390
5   libSystem.B.dylib             0x939f35c6 start_wqthread + 30
Thread 2:  Dispatch queue: com.apple.root.default-priority
2   libSystem.B.dylib             0x93a026dd mach_msg_server_once + 343
3   com.apple.QuickLookFramework           0x934c8498 _QLThumbnailWaitForCompletion + 161
4   com.apple.QuickLookFramework           0x934c8644 _QLThumbnailGetImageIfNecessary + 29
5   com.apple.QuickLookFramework           0x934c96bb QLThumbnailCopyImage + 130
6   com.apple.QuickLookFramework           0x934c97a9 QLThumbnailImageCreate + 160
7   ...inerobot.DeviceConnectivity     0x00468bc3 +[DRMetadataUtils setThumbnailForFile:] + 1101
8   ...ony-Ericsson-Bridge-for-Mac   0x0000fa1e -[DRContentOpSetThumbForFiles main] + 265
9   com.apple.Foundation                 0x925b4b5a -[__NSOperationInternal start] + 705
10  com.apple.Foundation                0x926a50bb ____NSOQSchedule_block_invoke_2 + 119
Thread 3:
5   com.apple.Foundation                 0x925c6224 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 329
6   com.apple.Foundation                 0x9258d4c4 -[NSThread main] + 45
7   com.apple.Foundation                 0x9258d474 __NSThread__main__ + 1499
8   libSystem.B.dylib             0x939fb259 _pthread_start + 345
9   libSystem.B.dylib             0x939fb0de thread_start + 34
Thread 4:  com.apple.CFSocket.private
0   libSystem.B.dylib             0x939ecac6 select$DARWIN_EXTSN + 10
1   com.apple.CoreFoundation         0x93581c53 __CFSocketManager + 1091
2   libSystem.B.dylib             0x939fb259 _pthread_start + 345
3   libSystem.B.dylib             0x939fb0de thread_start + 34
Thread 5:
0   libSystem.B.dylib             0x939fbaa2 __semwait_signal + 10
1   libSystem.B.dylib             0x939fb75e _pthread_cond_wait + 1191
2   libSystem.B.dylib              0x939fd3f8 pthread_cond_wait$UNIX2003 + 73
3   com.apple.CoreVideo                   0x97bf66fe CVDisplayLink::runIOThread() + 1016
4   com.apple.CoreVideo                   0x97bf62ea startIOThread(void*) + 156
5   libSystem.B.dylib             0x939fb259 _pthread_start + 345
6   libSystem.B.dylib             0x939fb0de thread_start + 34
Thread 6:
0   libSystem.B.dylib             0x939f3412 __workq_kernreturn + 10
1   libSystem.B.dylib             0x939f39a8 _pthread_wqthread + 941
2   libSystem.B.dylib              0x939f35c6 start_wqthread + 30
Thread 7:
Thread 8 Crashed:  Dispatch queue: com.apple.root.default-priority
0   com.apple.CoreFoundation         0x93624a37 ___TERMINATING_DUE_TO_UNCAUGHT_EXCEPTION___ + 7
2   com.apple.CoreFoundation         0x935d93f8 +[NSException raise:format:arguments:] + 136
3   com.apple.CoreFoundation         0x935d936a +[NSException raise:format:] + 58
4   com.apple.Foundation                 0x92641e0e -[NSMutableData(NSMutableData) replaceBytesInRange:withBytes:length:] + 354
5   ...inerobot.DeviceConnectivity     0x0046a5b8 -[DRMetaMP3 embedAlbumArt:intoData:] + 377
6   ...inerobot.DeviceConnectivity     0x00468fbb +[DRMetadataUtils fileDataWithInsertedAlbumArt:] + 446
7   ...inerobot.DeviceConnectivity     0x0043079f -[MSCDevOpSendFile doStart:] + 3092
8   ...inerobot.DeviceConnectivity     0x0042fb89 -[MSCDevOpSendFile main] + 348
Thread 9:
Thread 8 crashed with X86 Thread State (32-bit):
  eax: 0x00000000  ebx: 0x94e29585  ecx: 0xb0210000  edx: 0x0000003b
  edi: 0xa05fcab0  esi: 0x1e231160  ebp: 0xb020fb08  esp: 0xb020faf0
   ss: 0x0000001f  efl: 0x00000286  eip: 0x93624a37   cs: 0x00000017
   ds: 0x0000001f   es: 0x0000001f   fs: 0x0000001f   gs: 0x00000037
  cr2: 0x00fb9000
Binary Images:
    0x1000 -    0x8eff9 +com.sonyericsson.Sony-Ericsson-Bridge-for-Mac 3.0.1 (3111) <7E0AD9E9-4D19-39C3-8B77-AF53DEB3D7C3> /Applications/Sony Ericsson Bridge for Mac.app/Contents/MacOS/Sony Ericsson Bridge for Mac
  0x116000 -   0x138ff9 +com.sonyericsson.ContactSync 1.0 (1) /Applications/Sony Ericsson Bridge for Mac.app/Contents/Frameworks/ContactSync.framework/Versions/A/ContactSync
  0x151000 -   0x366fe3 +com.sonyericsson.framework.DeviceUpdate 1.0 (1) /Applications/Sony Ericsson Bridge for Mac.app/Contents/Frameworks/DeviceUpdate.framework/Versions/A/DeviceUpdate
  0x423000 -   0x482ff7 +com.divinerobot.DeviceConnectivity 1.0 (1) /Applications/Sony Ericsson Bridge for Mac.app/Contents/Frameworks/DeviceConnectivity.framework/Versions/A/DeviceConnectivity
  0x4c3000 -   0x4d8ffb +com.sonyericsson.SonyBridgeGeneric 1.0 (1) /Applications/Sony Ericsson Bridge for Mac.app/Contents/Frameworks/SonyBridgeGeneric.framework/Versions/A/SonyBridgeGeneric
  0x4ea000 -   0x4fdfff +org.andymatuschak.Sparkle 1.5 Beta 6 (313) <5DF2B8A3-560D-4500-6B85-4215644DE532> /Applications/Sony Ericsson Bridge for Mac.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
  0x50b000 -   0x5eeff7 +com.google.GDataFramework ??? (1.12) <1395D28E-6598-3D53-8EC9-E59499C058F1> /Applications/Sony Ericsson Bridge for Mac.app/Contents/Frameworks/GData.framework/Versions/A/GData
  0x6c3000 -   0x778fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) /usr/lib/libcrypto.0.9.7.dylib
0x15222000 - 0x152a6fe7  com.apple.xquery 1.3 (29) <983B85B3-9590-F3B4-C3B0-C73ADBC92C3F> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
0x23415000 - 0x2358eff7  GLEngine ??? (???) <76C922AA-A4A7-2835-537B-17F316AD95F6> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x235c0000 - 0x23604fe7  com.apple.driver.AppleIntelGMA950GLDriver 1.6.36 (6.3.6) <7AF9F4B2-DB83-354C-890F-2DA195AF185F> /System/Library/Extensions/AppleIntelGMA950GLDriver.bundle/Contents/MacOS/AppleIntelGMA950GLDriver
0x2360e000 - 0x23632fe7  GLRendererFloat ??? (???) /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x8fe00000 - 0x8fe4163b  dyld 132.1 (???) <4CDE4F04-0DD6-224E-ACE5-3C06E169A801> /usr/lib/dyld
0x90044000 - 0x90044ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x90071000 - 0x90119ffb  com.apple.QD 3.36 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x9011a000 - 0x9025dfef  com.apple.QTKit 7.7 (1791) <74F00760-A831-B8F2-869D-84C1F2366204> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x9025e000 - 0x90299ffb  libFontRegistry.dylib ??? (???) <19ED5DE0-D3AF-B229-9193-35D58FE377E5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x9029a000 - 0x905befef  com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x905bf000 - 0x905bfff7  com.apple.Carbon 150 (152) <8F767518-AD3C-5CA0-7613-674CD2B509C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x906bf000 - 0x90703fe7  com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x90704000 - 0x90705ff7  com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x90706000 - 0x90770fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x9078f000 - 0x90793ff7  IOSurface ??? (???) <89D859B7-A26A-A5AB-8401-FC1E01AC7A60> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x908d0000 - 0x908dcff7  libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
0x909ad000 - 0x90a3ffe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x90a4a000 - 0x90a62ff3  com.apple.ScriptingBridge 1.1.2 (???) /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x90a6d000 - 0x91350ff7  com.apple.AppKit 6.6.8 (1038.36) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x91351000 - 0x91479fe7  com.apple.WebKit 6534.57 (6534.57.2) <4CB86278-4657-3503-8042-074628222DF3> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x9154c000 - 0x91552ff7  libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <6EE825E7-CBA5-2AD2-0336-244D45A1A834> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x91553000 - 0x91556fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x91561000 - 0x915a3ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x915a4000 - 0x9161bff3  com.apple.backup.framework 1.2.2 (1.2.2) /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x9161c000 - 0x91a51ff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x91a58000 - 0x91b04fe7  com.apple.CFNetwork 454.12.4 (454.12.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x91b05000 - 0x91b52feb  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <00A1A83B-0E7D-D0F4-A643-8C5675C2BB21> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x921ce000 - 0x921dcff7  com.apple.opengl 1.6.14 (1.6.14) <82622F67-E032-0BF6-A78D-50B346E8D0FD> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x92245000 - 0x9244cfeb  com.apple.AddressBook.framework 5.0.4 (883) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x9244d000 - 0x9244dffb  libffi.dylib ??? (???) <58985323-6EC6-9AD2-B9F0-8787C0B2791C> /usr/lib/libffi.dylib
0x9244e000 - 0x92462fe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x9249f000 - 0x924b4fff  com.apple.ImageCapture 6.1 (6.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x924ef000 - 0x924fdfe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
0x924fe000 - 0x92520fef  com.apple.DirectoryService.Framework 3.6 (621.15) /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x92521000 - 0x92554ff7  com.apple.AE 496.5 (496.5) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x92555000 - 0x92576fe7  com.apple.opencl 12.3.6 (12.3.6) /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x92577000 - 0x927e8fef  com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x927e9000 - 0x929acfeb  com.apple.ImageIO.framework 3.0.6 (3.0.6) <5BF202E9-730A-3675-4374-E5300BC8ED10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x929ad000 - 0x929bdff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) /usr/lib/libsasl2.2.dylib
0x929fd000 - 0x92e13ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x92efe000 - 0x92f08ffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92f22000 - 0x92fbffe3  com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x93017000 - 0x9304dfff  libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
0x9304e000 - 0x93057ff7  com.apple.DiskArbitration 2.3 (2.3) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x930b4000 - 0x931b6fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
0x931b7000 - 0x931dbff7  libJPEG.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x931dc000 - 0x931ecff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x931ed000 - 0x931f7fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x932f9000 - 0x93379feb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x93388000 - 0x9338dff7  com.apple.OpenDirectory 10.6 (10.6) <0603680A-A002-D294-DE83-0D028C6BE884> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9338e000 - 0x93408fff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x93409000 - 0x934c5fff  com.apple.ColorSync 4.6.8 (4.6.8) <920DD017-8B41-7334-E554-A85DB99EBD5A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x934c6000 - 0x93504ff7  com.apple.QuickLookFramework 2.3 (327.7) <6387A103-C7EF-D56B-10EF-5ED5FC7F33A5> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x93505000 - 0x93680fe7  com.apple.CoreFoundation 6.6.6 (550.44) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x93681000 - 0x9397bfef  com.apple.QuickTime 7.6.6 (1791) <8E56F3DC-725B-0299-7E62-8599CA6EC4C0> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x939cd000 - 0x93b74ff7  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
0x93b75000 - 0x93c23ff3  com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x93c5d000 - 0x93d15feb  libFontParser.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x93d49000 - 0x93d65fe3  com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x93d66000 - 0x93dd5ff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x93f31000 - 0x94197ff7  com.apple.security 6.1.2 (55002) <3FA54D69-5476-78DD-0AFC-D6697263890E> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x94198000 - 0x94278fe7  com.apple.vImage 4.1 (4.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x94279000 - 0x94a68557  com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x94a69000 - 0x94bebfe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <50A70082-F800-93D8-1A7C-C95AAB1F352C> /usr/lib/libicucore.A.dylib
0x94c30000 - 0x94d0afff  com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x94d0b000 - 0x94d43ff7  com.apple.LDAPFramework 2.0 (120.1) <131ED804-DD88-D84F-13F8-D48E0012B96F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x94d86000 - 0x94d86ff7  liblangid.dylib ??? (???) /usr/lib/liblangid.dylib
0x94d87000 - 0x94d8bff7  libGFXShared.dylib ??? (???) <09540618-2ED1-72C4-61CB-938B35927568> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x94e13000 - 0x94e1eff7  libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x94e1f000 - 0x94eccfe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
0x94ecd000 - 0x94ecdff7  com.apple.Cocoa 6.6 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x94ece000 - 0x95c46fe7  com.apple.WebCore 6534.57 (6534.57.2) <6AF29D9A-F549-5BE7-3842-CFF75FC46360> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x96c06000 - 0x96c43ff7  com.apple.CoreMedia 0.484.60 (484.60) <8FAB137D-682C-6DEC-5A15-F0029A5B226F> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x96c44000 - 0x96c9cfe7  com.apple.datadetectorscore 2.0 (80.7) /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x96c9d000 - 0x96ca3fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x96ca4000 - 0x96d3ffe7  com.apple.ApplicationServices.ATS 275.19 (???) <2E83B3E9-AF39-36FC-5D05-CC1E952098AB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x96d40000 - 0x96d54ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x96e9f000 - 0x9735aff7  com.apple.VideoToolbox 0.484.60 (484.60) /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x974be000 - 0x974ffff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x97500000 - 0x97533fff  libTrueTypeScaler.dylib ??? (???) <8ADB7D19-413E-4499-C874-13C383F97685> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x97534000 - 0x97587ff7  com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x975c1000 - 0x975e9ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) /usr/lib/libxslt.1.dylib
0x9763c000 - 0x9763cff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9763d000 - 0x9763fff7  libRadiance.dylib ??? (???) <5F803B4A-B294-BA94-FB68-E8756EE41B20> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x9789c000 - 0x978a7ff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x97a8f000 - 0x97a90ff7  com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <93EC71F1-4D4E-F456-8EFE-32E7EFD7A064> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x97aa5000 - 0x97b70fef  com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x97b71000 - 0x97bf3ffb  SecurityFoundation ??? (???) /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x97bf4000 - 0x97c13ff7  com.apple.CoreVideo 1.6.2 (45.6) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x985c4000 - 0x9860bffb  com.apple.CoreMediaIOServices 140.0 (1496) /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x9860c000 - 0x9864cff3  com.apple.securityinterface 4.0.1 (40418.0.1) <2141A924-748E-CE6F-2D75-D82BC265BD30> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x9864d000 - 0x98650ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x98754000 - 0x98774fe7  libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <8C2B5FA8-2469-21C7-D297-F95A0FFE5F19> /usr/lib/libresolv.9.dylib
0x98775000 - 0x987afff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) /usr/lib/libcups.2.dylib
0x987b0000 - 0x987c8ff7  com.apple.CFOpenDirectory 10.6 (10.6) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x988a7000 - 0x989d5fe7  com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x989d6000 - 0x989d6ff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x98a0a000 - 0x98b16fe7  libGLProgrammability.dylib ??? (???) <6167CEB0-D8D6-C4D9-DD74-49755ADB540F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x98d43000 - 0x98ddbfe7  edu.mit.Kerberos 6.5.11 (6.5.11) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x98ddc000 - 0x98dedff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x98dee000 - 0x98df9ff7  com.apple.CrashReporterSupport 10.6.7 (258) <8F3E7415-1FFF-0C20-2EAB-6A23B9728728> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x98e25000 - 0x98e69ff3  com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x98e6a000 - 0x98f0afff  com.apple.Bluetooth 2.4.5 (2.4.5f3) /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x98f0b000 - 0x9935cfef  com.apple.RawCamera.bundle 3.7.1 (570) /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x99489000 - 0x994e6ff7  com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x99500000 - 0x99512ff7  com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x99513000 - 0x99519fe7  com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x9951a000 - 0x99647ffb  com.apple.MediaToolbox 0.484.60 (484.60) /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x99648000 - 0x99682fe7  libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) /usr/lib/libssl.0.9.8.dylib
0x99683000 - 0x996e4fe7  com.apple.CoreText 151.13 (???) <23F359DA-D845-5C50-4DF3-19E858CF2B2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x996e5000 - 0x99993fe7  com.apple.JavaScriptCore 6534.57 (6534.57.3) <5B18B308-DBB2-7133-DE56-494C2FA1848B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x999be000 - 0x999beff7  com.apple.vecLib 3.6 (vecLib 3.6) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x99cb9000 - 0x99d1dffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x99d1e000 - 0x99d2bff7  com.apple.NetFS 3.2.2 (3.2.2) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x99d2c000 - 0x99d5dff7  libGLImage.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x99d5e000 - 0x99d9bff7  com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x99d9c000 - 0x99da3ff3  com.apple.print.framework.Print 6.1 (237.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x99da4000 - 0x99dcaffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x99f2d000 - 0x99f30ffb  com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x99f31000 - 0x99f77ff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x99f78000 - 0x99f78ff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x99f79000 - 0x99ff4fff  com.apple.AppleVAFramework 4.10.27 (4.10.27) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x99ff5000 - 0x9a013fe7  libPng.dylib ??? (???) <5B979A83-8CE7-6BD7-B84C-A2D1119B378D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x9a014000 - 0x9a064fe7  libTIFF.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x9a06f000 - 0x9a16ffe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) /usr/lib/libxml2.2.dylib
0x9a170000 - 0x9a1b3ff7  com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9a22e000 - 0x9a599ff7  com.apple.QuartzCore 1.6.3 (227.37) /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9a625000 - 0x9a945ff3  com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x9a946000 - 0x9a9fffe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
0x9aa00000 - 0x9aa03ff7  libCoreVMClient.dylib ??? (???) <37F56237-4ABA-E5B5-968D-70FFE357E8E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x9aa04000 - 0x9aa08ff7  libGIF.dylib ??? (???) <9E51F8ED-83B4-DA41-1E2F-CFA726936A30> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9aa09000 - 0x9aa0bff7  com.apple.securityhi 4.0 (36638) <6118C361-61E7-B34E-93DB-1B88108F8F18> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x9aa0c000 - 0x9aa4fff7  libGLU.dylib ??? (???) <6CC3CE6A-7024-C685-EADA-7F9DC27128E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9aa50000 - 0x9aaa0ff7  com.apple.framework.familycontrols 2.0.2 (2020) <596ADD85-79F5-A613-537B-F83B6E19013C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x9aaa1000 - 0x9abdefe7  com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <423BDE4D-5082-B6CA-BB2C-E22A037235A4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
Model: MacBook2,1, BootROM MB21.00A5.B07, 2 processors, Intel Core 2 Duo, 2.16 GHz, 2 GB, SMC 1.17f0
Graphics: Intel GMA 950, GMA 950, Built-In, spdisplays_integrated_vram
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x87), Atheros 5416: 2.1.14.6
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: FUJITSU MHW2160BHPL, 149.05 GB
Parallel ATA Device: HL-DT-ST DVDRW  GSA-S10N
USB Device: LT30p, 0x0fce  (Sony Ericsson Mobile Communications AB), 0xe182, 0xfd100000 / 3
USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8501, 0xfd400000 / 2
USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8240, 0x5d200000 / 2
USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8205, 0x7d100000 / 2
USB Device: NetScroll + Traveler, 0x0458  (KYE Systems Corp.), 0x002e, 0x3d100000 / 2
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac  (Apple Inc.), 0x021b, 0x1d200000 / 2
