Problem with earphones
Chetas45
It all started when my JVC XX stopped working one evening. I kept trying to figure out what the issue was. Turns out my JVCs work just fine. I tried a friend's Senheisser and there was no output throught the headphones until I pressed it down the 3.5mm slot hard enough. Every time I want to use earphones I have to give it a nice hard push, and as soon as the pressure is lost, the music stops. This is the second time I've had issues with the Go. It really isn't turning out to be the phone I was expecting it to be 😕
Any solutions?
Sam
Legend
Legend
Given the nature of the problem described, I would have to advise that you return the handset so that it may be assessed by an authorised repair agent.
