Problem with driver device software!
Good day guy,
I got problem with my xperia x10 for updating to the last version
actully i was using this phone and when i knew that there is an update i said lets update it maybe i can use it again.
The problem is!
when i connect the phone to PC (windows system) the sony erricson doesn't find the phone automaticlly i should click on some message on the phone to know it.
when the sony erricson software knows the phone it shows a message that if i want to update it
i click on update
- i have to disconnect the cable from both sides PC and Phone .... and i do that
- I turn of the phone
- i re-connect the cable to PC side and while i'm connect it to phone side i have to press and hold a back bottom for the phone ... and i also do that
now,
the PC searching for the driver device software ... and shows a message click to search it or tell me later or do not shows tha message again
i once click on search
then the PC going to discover it not found any thing then shows a message if i have a disc software i click i dont have then if i have a copy on the PC i click on this but i dont know where the file is ... so i got a faild message
and once i click on tell me later
i got directly faild message
i tried to turn off all the secuirty software on my PC
I tried to go on phone setting and then applications then and i tick on PC companion installation i tried to remove also the tick
i also un tick on USB debugging from the Development from application setting
alll my tries faild
anyone can helo me please?
2 REPLIES 2
the problem is with the
SEMC Flash Drivers
just to noted you:
my phone is officailly unlocked
because i bought it from my country not from USA or the countries which sales locked phones
Johan
When you PC tells you to search for driver try to manually set the path to the drivers folder within the PC Companion folder. Then it should be able to find your drivers. If not I suggest that you try using another PC.
