Problem with clock
ichabodcrane
Problem with clock
Some days ago i noticed that the clock goes back in time while the screen is off. Once you switch it on, you can see how the clock updates. The problem is that I use the cell phone to wake up, but the alarm sounds late due to the problem of the clock. I already tried to change automatic updates but I didn´t success. Any idea? Thanks
6 REPLIES 6
watsonbeh
Just turn off your battery extended mode in settings. :smileygrin:
florenzgonzales
also try looking at the date and time settings if its checked with automatic time with carrier..
ichabodcrane
I already tried both things, No success. What else?
florenzgonzales
thats weird but how about software repair?
sohel4r
i am faching same problem!
Rickard
When you turn on the display the clock displayed on the lock screen might take a second or so to update. This does however not affect the alarm.
If turning off automatic time/timezone doesn't help i recommend that you check so that you don't have any task manager/killer installed. Those can kill the alarm app.
