Hi everybody
Its less than a month that I bought a mini pro but my problem starts very soon
the problem is that when plying or working with amount of (for example) 54% of battery without 15% warning shone shows 1% warning and then "shutting down" after that when charging it starts from 54% again...
I think that battery works good but amount of battery is wrong
tried to calibrate it several times but it doesn't work
what's the problem, and where is the solution?
tnx a lot and sorry for any grammar problem.
Backup everything then repair your phone w/ Update Service
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
don't forget to mark the Correct & Helpful Answers
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
and if you want to debrand your phone
Neo 2.3.4 Update 4.0.1.A.0.283
http://talk.sonyericsson.com/message/110585#110585
Xperia Neo 2.3.4 Update 4.0.1.A.0.42
http://talk.sonyericsson.com/thread/29084
also you can use Translate.google.com
thanks alot for your support
but Update Service says that your phone is up to date.
yes, but doesn't it give you an option to install anyway or repair your phone?
I used a method that originally is for Motorola phones.
I recharged the phone fully (up to 4160 mV) then turned off the phone, and removed the battery for a while and connected the charger again and waited for full recharge again, then turned on and till now it works fine.:smileyhappy:
but what's going on in next hours is critical for me.
I wish to see 15% warning again
yeah it works.:smileylaugh::smileylaugh::smileylaugh:
hey guys, i'm also having this problem with the mini pro..
can you pleaase tell me what to do??
I didnt quietly understand what to do..
please somebody help?/
