Hello everyone
when I enter application music and want to go to Track part a massage appears and say:"Sorry! The application Music(processcom.sonyericsson.music) has stopped unexpectly. Please try again. " and there is a button at the end of massage :"Force close"
what should I do to solve the problem ?
(I have xperia neo v)
I would advise running a software update:
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connectionn steps
but I can't connet my phone to computer via media transfer mode
If you follow specifically the method above this will be done with the phone turned off so this shouldn’t be a problem.
but when I try to do 10th step I've got an error "unable to install or start phone software update compnents " what should I do?
