problem wifi signal
micuosepeck
problem wifi signal
Hi I have a problem with the wifi signal has little intensity I have a xperia acro s,, I was going with the xperia u
Johan
If you're having problems with weak signal you could try to change the channel on the router. You can use Wi-Fi analyzer from Play Store to check which channel that would be best to use.
