Problem synching in Facebook
For a while now my experia arc has been trouble sync'ing with integrated FB.
Looks like it is related to Syncing Albums in galleries.
I get a message saying Sync is currently experiencing problems.  It will be back shortly.
Is anyone else getting this?  It's annoying when I clear everything up top, but this blue F keeps coming back!!
Help!
Mechman
4 REPLIES 4
where do you have that problem with the gallery or with the integrated phonebook or with the facebook app?
It is in the integrated facebook program, and it looks like it is only the Sync Albums in Gallery.
I try to remove the account, but it automatically comes right back.
try to remove the regular facebook sync first or backup everything and do a factory reset
settings -> privacy -> factory reset
make sure you backup everything beforehand
this is how
Use one of these links to download the Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
