Hi, having problem syncronizing with my google calendar, after ICS update.Does anyone have a solution
Can you please provide more details as we are unable to help if we are unaware as to the issues you are expirencing,
Sorry for the inconvenience.
hi, have the same problem too.
my problem is all the calendar in my phone for current months is there. but for the previous months and way back, is missing.
thanks.
This seems to be a google issue rather than a phone one. I recently did a factory reset on my Neo and when I went to resync the calendar it will not sync anything past the last 60 or 90 days.
The only way around it, having done a google search on the issue, was to buy the Calengoo calendar app. I had always used Jorte calendar app which was free but I rely on my phone for calendar history and couldn't be without it. Needless to say I wasn't very happy to have to buy my way out of an issue but it works so guess I will have to live with it!
I could sync my contacts,bookmarks and picassa but not the calendar.My phone calendar is now showing only indian holidays but not the birthdays, reminders which are stored in google calendar. The Google Calendar still shows all of my entries. Even after the ICS UPDATE I could sync all, the problem arised recently.
Hi I had the same problem with my phone.......i don have a solution to ur prob but i did happen to solve it with a workaround.....i installed this free app from play store called "Business Calendar Free"....once i did this the google calendar sync worked jus fine......den i uninstalled the app :smileysilly:.....not sure if it'll help you but u can try this 🙂
i already using Business Calendar paid version. factory default 2 times, but stil the same. only current month google calendar is there, but previous few months is only some yearly birthday.
Doesnt work, still says google syn not working.
here the trick.. just found out yesterday.
go to google calendar, settings. than export your calendar. after than import the same as the export. no need to worry about duplicate as it will overwrite. this will make google calendar that you just added a new events in, thus will display all the events again.
hope this help..
