Problem: Notification Sounds and Ringtones
mohsen643
Hi
Did a silly thing. I went to Root, system, media, audio and replace the Ui folder with that of xperia z3 I'd downloaded from somewhere. Before doing so, I copied the xperia V's own Ui sounds and save on ext card. Now  sounds such as key press, dial pad sound, etc. don\t play. I even replaced the original copied ui sounds but no change..
could someone help please?
3 REPLIES 3
Thommo
Genius
As you have root then PC Companion will not work for you which leaves a manual flash using Flashtools and a .ftf firmware file
mohsen643
Tnx for your reply. How about a factory reset?
Thommo
Genius
You could certainly try but if you have deleted items from the root then I'm not sure a reset will return these items
