Hello,
I have a problem after updating to 4.3 adroid with the notification led.
When i make a call it always stays on blue.
Any ideas how to fix that problem?
I also feel that the battery is heating up a lot more after the latest update!
Thanks for your help!
Hi wdv
Since the LED light is not acting as it has to be, i beleive you have tried to update the firmware??
Me2 had same issue before later after updating the firmware(without any issues, broad band need to be fast, no break up in power ), later everything is fixed
what i suggest is
>try to do reset, if you have tried it already then
>try doing hard reset, connecting the phone to the computer then press and hold volume up button for few secs later, press power button , unitll you can see safe mode screen, you can reboot later and see it occurs same
>even if it didn't work as you expected , then you can try to RESTORE the phone to factory settings (MAKE SURE YOU HAVE EVERYTHING BACK UP , SINCE YOU WILL BE LOSING EVERYTHING ON PHONE ), this might do some trick
>last but not least, try to update firmware again, make sure you have fast internet this will do some work
let us know
Manjuboyz
NOTE:
Rate me If you are happy with my Resolution, Thanks
for always on led you have 2 way
1.go for 3rd party apps and turn off light effects from phone and let the 3rd party app handle lights
2.just press power button once when light goes on
after some days of working battery overheating will be fixed
