How can I update my xperia p application through a wifi ,which is enabled proxy and authentication with pc companion ? The pc companion has it own proxy setting, but no authentication is asking . and when i going to update my phone,the message showing "sony update engine failure"(error 1100).
<script type="text/javascript">// var vglnk = { api_url: '//api.viglink.com/api', key: 'a187ca0f52aa99eb8b5c172d5d93c05b' }; // </script> <script type="text/javascript" src="http://cdn.viglink.com/api/vglnk.js"></script>Not sure if it will work if you are required to enter a user/pass for the proxy. You could set PC Companion to use system settings instead and make sure you have correct setting under Controlpanel -> Internet options and see if it works.
You could also try Update Service and see what happens: http://www.sonymobile.com/global-en/tools/update-service/
