Problem in update
S_H_A_N_I
Problem in update
hello dear , i m trying to update my xperia u, but dont know wats happening ...... i m tired of it
I followed the whole procedure for update using pc companion, at the end when it says switch off phone,plug it again with pc while pressing volume down key.... i pressed the vol  down key for several minutes but nothing happened.....!
please anybody help me
many thanks
10 REPLIES 10
andym
i'm having the same problem for 1261-9042. Have tried it with pc companion and the Sony Update Service but still nothing happens when re-connecting phone with volume down key pressed. Any help much appreciated!
Rado77
It's not about how long you press VolDOWN button, but when you press it. It's little bit tricky, I also had to do it twice. You have to press VolDOWN and at the same time plug cable. After 2-3 seconds PCC should show message like "Now you can release VolDOWN button"
andym
ah ok. So if you press and hold volDOWN, and then plug in usb it shouldn't work? You need to do both at the same time...? Cheers
jatinrungta
Enthusiast
Yes at the same time and after its done half green light will light at the bar.
If you got time then please visit here:::::::::::::::::
Custom Roms::
http://talk.sonymobile.com/thread/56689?tstart=0
If you are rooted then please visit
http://talk.sonymobile.com/thread/56641?tstart=0
http://talk.sonymobile.com/thread/56642?tstart=0
If you want to root:
http://forum.xda-developers.com/showthread.php?t=1886460
Please Mark
  • Correct Answers
  • Helpful Answers
S_H_A_N_I
Is that worked then?
S_H_A_N_I
andym
i'll try it when i get home from work tonight... cheers for your help. will let you know.
S_H_A_N_I
Lolz, am also at job as well, ll try at night
jatinrungta
Enthusiast
LOL
