problem creating backup file
pastelrei
I recently experienced a problem while creating a backup file. I used to have a 2gb card and the backup process runs smoothly in it, i tried using it today and still working fine. Last week, I bought an 8gb card for my TX and the photos and music files are working fine. However, when I tried to create a backup last night, it suddenly hanged in the middle of the process. When I cancelled it, my phone then hanged too. I could not turn it off unless I remove the battery.
Could this problem be isolated with the SD card I am using? Or does it has something to do with my phone? Also, I noticed that my battery drains fast now, even after the reset. Could this be caused by the SD card too?
Any help will be appreciated. Thank you.
4 REPLIES 4
shihstouch
Enthusiast
What Speed Class rating is your SD card.
if it is a local brand with low speed it can cause your phone performance...
Check below link for more details...
https://www.sdcard.org/developers/overview/speed_class/
pastelrei
It is a class 4. Is that too low? I was able to create a backup later today but I had to divide the backup into two small files instead of creating just one backup file. I also repaired my device using SUS, so it is basically on its bare state now (I did not restore my previous apps yet), but I still notice a fast battery drain even with the data off.
shihstouch
Enthusiast
Try using third party apps like My Backup to backup your files...
https://play.google.com/store/apps/details?id=com.rerware.android.MyBackup&hl=en
pastelrei
Thanks. I encountered another problem today, while using the camera and accessing the photos. The phone suddenly hanged. It seems that this happens everytime I access resources from the SD card. I should probably buy a new one. May I ask what speed you use that is compatible with the TX? thanks.
