Hello
Yesterday I made a connection between your phone and PC via USB
After removed the phone from the computer, I figured the problem, namely:
When I press the Menu button, I get this message:
configuration error. please contact your network operator or service centre.
All the buttons work, but when you press them, does not show anything (I mean it does not have a technical problem)
:smileyinfo: I think that one of file system may damage, therefore, the phone no longer works well, and I think that the right solution is in the (Master reset), but I can not run (Master reset) because the button (Menu) does not work :smileyshocked::smileyshocked:
Is there a manual method (in Nokia can do something like this by pressing this buttons *+3+call button+power button), or any other way to do it (I mean the Master reset) ????
Any solutions or suggestions
Thank you very much
Have you tried removing and re-inserting the battery?
I have tried it, nothing has changed, same problem
Thank you for your interest
Then try running the SE update service via PC, since the phone has to be switched off anyway.
Thank you again
I have tried it, but unfortunately, does not work
Since the problem appeared, the phone no longer works with USB, charger only is working
Is there any way I can access to the Master reset???
Not that I know of.
I would say that this phone need to be fixed at a repair center. Contact your local support team for more info about local repair centers.
http://www.sonyericsson.com/cws/corporate/common/contact/phonelist
