Powerbutton does not turn screen on (something to do with proximity detector)
Penafore
I can lock the phone using the power button just fine but can't turn it back on using the power button I would need to connect/disconnect my power to make the screen light up again. It started happening when I updated the system to the last update(the update before current version) I believe it has something to do with the proximity detector (using a screen guard that covers it) when I remove the screen guard it works fine... But the screen guard is sort of expensive (tempered glass) and it be a shame if it would be a waste... Is it possible to deactivate the proximity detector? Or is it OK to cut tempered glass?
Also during a call it turns screen off once the person hangs up, I can't light the screen up at all the only way is to restart the device.
I've tried *#*#7378423#*#* and I didn't find the calibration option, I've been searching the webs those screebl, gravity screen does not work
please help
4 REPLIES 4
Penafore
Ah I posted this on the wrong place, I'm using Sony xperia Z
*moved thread to Xperia Z/ZL/ZR (by Hampus).
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Penafore
I will try that out once my computer gets fixed, for now is there any other way?
Penafore
My Computer (Windows 😎 cant detect my phone when in MTP connection(was going to backup), when i go to device manager it shows in the "Other Devices" section as C6602, however it seems like my computer doesnt know what it is, it seems like my computer does not have a driver for MTP... Please help
Device Properties (On Puush)
Events Page :
Device USB\VID_0FCE&PID_0193\BX903FRCPA was configured.
Driver Name: null
Class Guid: {00000000-0000-0000-0000-000000000000}
Driver Date:
Driver Version:
Driver Provider:
Driver Section:
Driver Rank: 0x0
Matching Device Id:
Outranked Drivers:
Device Updated: false
