hi every one ,
i'm using xperia u running ics c.0 (rooted) ,i have problem with the power management i marked the option of extended standby mode , but still it's not working sometimes (after lock the screen ) , also how can i change the timeout of it ???
also one more thing , the app key in the home screen how to make it circle instead of square shape ??
thank you .
What do you mean extended mode doesn't work? It should disable data traffic while the screen is turned off.
And for timeout, go to Settings>Display>Sleep and then change it to whatever time you want.
For the lock screen, the easiest way would be to install a 3rd party lock screen such as this one. https://play.google.com/store/apps/details?id=com.teslacoilsw.widgetlocker&feature=search_result#?t=...
Please Mark
