POWER KEY
bahar1394
POWER KEY
hi. i buy a phone (xperia E3 dual) but when i want to use it , power key action is low and may turn after one minutes ( i think it may be hanged). what can i do to solve it? Slightly_frowning_Face
3 REPLIES 3
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Thommo
Genius
If that fails and you bought it new and have proof of purchse then you would need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
Jake-SonyXperia
Hi bahar1394
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
I don't quite understand the query, can you supply more details about the issue?
