Power button does not respond to wake up
Gerrybws
New
Hi my xperia Z power button is unresponsive for unlocking my fone, for some reason it allows you to lock it but not unlock, so every time I want to use my phone I have to connect the charger
Thommo
Genius
Try performing a system repair as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
