Possible to Factory Reset Sony Xperia Z2 without unlocking the screen?
kripticula
Basically, I bought this phone, dropped it a couple weeks later, screen smashed to peices, don't have the money to replace it, but my friend wants to buy it off of me.
I have a lot of personal information on there already that I don't really want him to have access to, so is it possible to reset it to factory settings without unlocking the screen?
Thanks in Advance, Krip.
3 REPLIES 3
Thommo
Genius
Performing a system repair will factory reset your phone - see below for details or you can connect a USB OTG cable then connect to that a USB mouse and control your phone if you can see the picture on the screen if not follow the below
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
kripticula
Thank you for replying so quickley.
I followed these steps but it keeps coming up with PC Companion was not able to connect to the phone / tablet. Please disconnect and connect again.repair.png
kripticula
bump
